When I open Maps and select Around Me, I get the never-ending loading maps screen. Anyone else seeing this or know what's going on? Hard restart didn't help and maps are up to date.
Yes, I am using the "Map" app outside and I am getting a GPS fix with a map displaying my correct location. The problem is once the map is displayed and I select the "around me" function, the watch then goes to a "loading map" screen and stays that way until I back out of the application. If working properly, it should display "loading map" for a couple of seconds and then display POI for my location.
Solved. Or at least a solution. I'm not sure if this is by design or a bug, but I went ahead and reported it to support. In "settings" for "map", if "orientation" is set to "north up", the watch will get stuck with loading map if you select "around me" in the "Map" application. For the "around me" feature to work, "orientation" must be set to "track up".
Update: confirmed by support and they're looking into a fix.
