I have used Garmin watches for 6 years so very familiar on how to use and get around on them.
I raised this issue with the support team. It is a known issue. Hope they resolve it soon. Meanwhile, they recommend opening up the watch folders on a computer and deleting files from the watch's workout…
I ran into this issue as well. As you stated, you can delete a running workout by starting an activity then long press menu (Up button) > Training > select the workout, then either "Do Workout" or "Delete…
Thanks. I assumed there might be a way to do it this way but had not tried yet. Will do this if needed.
I ran into this issue as well. As you stated, you can delete a running workout by starting an activity then long press menu (Up button) > Training > select the workout, then either "Do Workout" or "Delete." No such option for a strength workout. The way I've been removing strength workouts is by connecting the watch to a computer. Open the drive associated with the 945 LTE, then browse to the \Primary\GARMIN\Workouts folder and delete the workout in that folder.
I have the exact same issue, it's still not possible to delete a strength workout on my Forerunner 945.
I raised this issue with the support team. It is a known issue. Hope they resolve it soon. Meanwhile, they recommend opening up the watch folders on a computer and deleting files from the watch's workout folder.
2 years later, still not fixed. I am starting to get tired of encountering an issue with Garmin, looking for an explanation/solution online, find out in the forum that it's known for years but not fixed.
Unbelievable.
Edit: well, it IS possible now.
Open a Strength activity profile, highlight the workout you want to delete, enter (Start button), enter (Start button) again, select Delete
Thanks seilogramp
Looks like the 945 didn't get the workouts app, but the 945 LTE did.
Forerunner 945 LTE Software version 16.18 - Forerunner 945 LTE - Running/Multisport - Garmin Forums
Adds a Workouts app to the Activities & Apps list.
I've since moved on to the epix (Gen 2), but it's the same app and it allows me to delete workouts.
Open My Workouts, select workout, delete.
