Bugs in 4.16 :/
So, I saw these issues in the 4.07 beta, but I was hoping at least some of them would be fixed in the production release.
- Cannot Pan/Zoom map page during a paused run activity (after the activity has been started). Around Me and Save Location are also missing from the menu. This seems to really limit the usefulness of the map page. (This is not during navigation, if it makes a difference.) All of these options are available while the activity is unpaused.
- Connect IQ data field apps always believe the background color is white, even if it's actually black. (This causes all the text in Stryd Power Zones to be invisible, because it's also black): https://forums.garmin.com/developer/connect-iq/f/discussion/277505/datafield-getbackgroundcolor-returns-color_white-when-background-is-black-945-lte
- Strength app doesn't remember weight from previous set. (The weight is always reset to zero, which means that you have to edit every set.)
- Stopwatch time and laps are invisible after starting stopwatch, pressing UP (for options), selecting Go to Watchface, then returning to the stopwatch. (The time reappears when you pause the stopwatch, but disappears when you restart it. Apparently, the only way to get the time and laps to display again (while the stopwatch is running) is to reset the stopwatch.
On a more positive note, at least the bug has been fixed where CIQ data fields crash and restart when you return to the watchface during an activity.
  • Another bug, since I got a heart rate monitor Polar H10 the battery went from 60% to 10% overnight. I recharged to 100 removed the heart rate strap and it went from 100-80 from 1am to 12pm. I don't know what is going on I had flight mode and battery saver both on and I don't install any widgets or faces
