Someone already reported it and you locked the thread please fix this issue.
I have a playlist downloaded from Spotify when I connect my head phones I get a blank screen. I tried restarting and nothing has worked so far.
I am also having this same issue. Infuriating. May have to go back to the Apple Watch
I am also having the same issue. It's so aggravating. Please email me
Hi, this just happened to me today. What is the fix? My Epix is up to date.
Having the same problem on my Forerunner 945 which is up to date. Please email me.
Thanks.
All,
Is this happening when you use Spotify, or are you using a different music source? Can you please see if there are any updates available for your music app within Connect IQ? It should be on version 1.6.6. If it is not update, follow these steps:
Open the Garmin Connect app.
Access the menu by selecting More (bottom right).
Select Garmin Devices.
Select your device.
Select Music.
Select Music Providers (skip if you do not see this option).
Select Spotify.
Select Update, if available.
Yes, I'm using Spotify. There are no updates available through Connect IQ or following the steps provided.
I had the same issue.
To solve this problem, I uninstalled the Spotify app and install it again. Then I did whole configuration of the app once again (import playlists, connect headphones)
