Please, help me confirming and updating this list.
Bugs:
1- Stair stepper activities are recorded by Strava as if they happened in the future. Real example: activity happened at 9:53am, but Strava says it happened at 17:53 (same day). This doesn't occur when running or cycling. I checked and it seems stair stepper (and all indoor activities) has no GPX file support (probably because it has no GPS information), so this may be confusing Strava.
2- If you add/remove an activity type from the watch, then all data screen settings are reset to default.
3- When reviewing a running activity (potentially any activity with more than 4 laps) from inside the watch, if you scroll down to the lap list, you'll see something like this:
Lap 1 5:27
Lap 2 5:33
Lap 3 5:46
Lap 4 5:45
If the activity has more than 4 laps, you need to scroll down to see the other laps, so you may see something like this:
Lap 5 0:36
So far so good! However, if you scroll up to check the previous laps again, you'll see something like this:
Lap 1 5:27
Lap 2 5:33
Lap 3 5:46
Lap 4 0:36 <-- notice that this is wrong, since it's the pace of the lap 5 from the other page
Once it happens, you're not going to be able to see the actual pace for the lap 4, unless you go to the watch face and load the activity review again.
4- This is random: sometimes you're using the watch and see the battery percentage going to 20% and after a few minutes it goes back to 40% and remains there for hours;
5- Some users have been reporting issues when trying to turn on the device: forums.garmin.com/.../forerunner-45-sometime-doesn-t-turn-on
6- Alarm goes off at random times occasionally: https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-45-series/172157/alarm-rings-automatically
7- Weather widget doesn't always work as expected: https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-45-series/164947/weather-widget-problems
Dubious features and/or requests:
1- Backlight turns on every time an automatic action happens, like acitivity auto paused/unpaused, activity sync, etc;
2- Why can't we see the elevation gain information on the activity review on the watch?
3- Snoozing alarm: https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-45-series/194297/snoozing-alarm
4- Alarm order: https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-45-series/194296/alarm-order
