Anyone else have a problem with weather widget? Mine won't load the data. Just got the Forerunner 45 today. Seems peculiar.
Make sure you have location services enabled on your phone, and maybe do something on the watch with GPS, just to make sure both know your location. Then give it maybe 15 minutes. I think it uses your phone for the location, but may use the location from your watch as a backup or something.
The watch also needs to be connected to your phone.
Hi everyone, I am having the same problem. setting on the phone doesn't help. You must going into the watch setting, then system and then units. Only then you can select celsius or farenheit
Thank you I got a bit confused but from the watch face pressed the left bottom button to cycle to the weather widget and then the middle button as above. the option takes a moment to work so don't be impatient :)
This worked to change the temperature to Celsius, but it still shows the wind speed in mph!
Mine only has an option to change miles-kilometres… there is no option for F-C
