Max Heart Rate and Lacttate Threshold too high?
Hi,
Some context: I have had a ForeRunner 265s for a couple of years now. I am 32yr old male, and consider myself to be of average/decent fitness. I have peaks and valleys with training, but try to run a half marathon at least once a year (my fastest one being 2h06m). Also, my Garmin currently has my VO2 Max at 49, but once peaked at around 52.
In the past, I had some issues with the watch getting locked at a specific heart rate during runs. In some instances claiming very low unchanging heart rate during high intensity running. Due to this issue, I now use a heart rate monitor during my runs.
All that being said, I think my auto-detected max heart rate is very high, currently sitting at 208bpm, and my LTHR sitting at 188bpm. These numbers are actually lower than they once were. These numbers used to be 220 for Max HR and 191bpm for LTHR. I manually adjusted them down earlier this year as they were absurd and my zones were not representative of how I felt. Even now, these numbers keep slowly climbing, even though I took a big hiatus from training. I feel like there may be something wrong with auto-detection.
Any help or input on this would be appreciated. Anyone else experienced this and fixed it somehow? Thanks!
  • LTHR detection under the old system, which required a heart rate strap, was quite good in my opinion. When the new system rolled out, around September of 2024, the rates it detected went up significantly. It seems to have gotten better over the course of the year, and LTHR is basically right on again for me. Max HR detection will still be about 5 bpm too high for me - 175 instead of 170 in my case.
  • I see. I never got to use the old system, so I can't compare it, but right now my detected Max HR is 206bpm, which seems extremely high to me. My LTHR is sitting at 188bpm right now, which also seems a bit higher in my opinion, me knowing my fitness level.
    Perhaps I should manually change it to a value I think makes sense, and see how it re-adjusts. Anything you did that helped get better LTHR calcualtions?
