Night mode (red) stays on after wake up
Since the last update, my forerunner 265S stays on night mode (red) even after wake up time, even showing the morning report in red. I need to manually deactivate red screen in sleep mode to come back to normal, and then manually activate it to red when going to sleep. How can I fix that? Thank you for your help
  • Same here. I rebooted but next morning same issue again
  • All, we are looking into this concern. We do have a public work around for now.
    Change the wake-up time by at least 1 minute.  After the wake time modification, Red Shift should disengage on that day of the week.  So, a wake time modification will be necessary for each day of the week to achieve a full work around. You will need to change the wake up time every day by 1 minute.
    If the work around does not resolve the concern please let me know if turning the device off and on resolves it after 12.70 update.
    This is still being looked into, I thank you for the patience!
  • I am on v25.04 and used the red shift during sleep, for the first time last night. And it continued to remain on today morning even after sleep mode ended. I had to power-off and power it back on to fix it.
  • To confirm, you had to turn it off and on to get it out of that state or it fixed it indefinitely?
    Do I have permission to add you to our case if it was just a temporary fix?
  • I had to turn it off and on to get it out of being stuck in red shift.
    Similar today morning.. This time, I woke up before the scheduled time and manually switched off Sleep mode. But that did not get it out of Red shift. I turned the watch off and on, and then (sleep mode was back on) when I turned off Sleep mode, Red shift also turned off.
    So looks like I have to do it each time.
    Sure, please do add me. What does that entail?
