Blue Triangel
Since Today I keep getting a blue triangel. It started when I tried a "run" activity.Had version 20.xxx and have now updated to the latest possible version. But same thing happens. Only now it shows up at the start page without going into activity.Have tried Hard reset but the watch keeps showing after awhile the blue triangel and tries to restart by itself.
Is my watch dead?
  • Maybe you have an incompatible addon from the IQ store that is crashing? Could be something like a watch face or data field?
  • Tried with deleteing the one watch face and data field I had. But still same problem.
    The only difference yesterday was a new course I had set up and that I used Livetrack.
    But after that I have hard reseted, aswell as updated the firmware. But with that it got worse so now it goes blue directly after restart. Says "loading FTX files" or something and then goes blue triangel.
  • You probably need to contact Garmin support, but it sounds like you have a corrupt file somewhere possibly an imported route file or similar. If you can't isolate it the (2nd) worst scenario is you might need to do a factory reset, which will mean you'll have to set up the watch from scratch again.
