Other roads and junctions not displaying in Course
Hi,
When following a Course, the red line only displays the exact course but not any other connected roads. E.g., when approaching a crossroads, the Course only displays a straight road with no junctions.
I'm not sure if this is a pre-existing feature or a new glitch following recent update. I think it's new as I seem to recall previously seeing the complete road layout as well as the red line Course.
Or is there a way to configure Map Navigation settings to show/hide connecterd roads?
Thanks
M.
  • The Forerunner 255 does not support maps.
  • Thanks ovekvam.
    So what Garmin calls a "Map" is only a GPS trace (Route)? That would explain why connected roads/junctions dont show.
    But the User Manual sets an entirely different expectation. It distinguishes Route v Map when it says "your route is marked with a line on the Map". All very confusing and dissapointing. A Garmin device that does not do maps.
  • Garmin clearly states 255/265 does not support maps, only 955/965 does, nothing to be disappointed about
  • I guess you should know what you're buying in the first place
  • In case this is of use to anyone.  I've figured-out an adequate workaround. . .
    When plotting a new course, I deliberately plot the course to slightly overrun into unitended roads at selected junctions - especially at rural "Y" junctions - by placing (false) route markers about 50M beyond the junction and into each unintended road. In this way, the road outline of what might be ambiguous junctions on the ground will appear on the watch.
  • I sympathize with OP, but I can also see it from Garmin's POV as well.
    - Garmin is clearly using "map" to mean 2 different things depending on the context:
    -- "map" as in map page: this is the page which shows the GPS track / breadcrumb trail and current route/course. It also shows any user-saved locations. It's kind of like a map, in that it shows you where you are and where you're going, as well as any locations you saved. It just doesn't show you any surrounding features.
    -- "map" / "maps" / "mapping": fully-featured maps which show streets, buildings, trails, place names, etc
    Thing is, does anyone have a better name for the "map page" which is 100% clear and would actually fit on the tiny UI of a watch? "Breadcrumb trail page" or "track page" don't really have the same ring as "map".
    Even COROS uses the word "map" for the page that your track / route appears on, even for devices that don't support "mapping" (like their PACE watches):
    https://support.coros.com/hc/en-us/articles/360039841072-Using-Navigation-Features
    I think we just have to accept that natural language is ambiguous, and people are going to use the word "map" to mean different things in different contexts.
    The same thing happens with online and irl discussions all the times - half the time people are arguing past each other because two people use the same word but with different meanings.
    Yeah they clearly state that 955/965 have mapping, due to their specs pages featuring a "Maps" tab and a specs line which says "Built-in Mapping". 255/265's spec pages lack both of those things.
    But is it really always "clear" that the omission of X means that X is not supported? We can probably think of a ton of little features that aren't necessarily on the specs sheet. (Then again mapping isn't a little feature).
    To be fair, no specs sheet or manual will go out of their way to tell you what features a device *doesn't* support.
    Strictly speaking, Garmin does not "clearly state" 255/265 does not support maps, it's implied by omission (and by comparison).
    I think one of the biggest legit complaints about Garmin is that there are just way too many models. Garmin has released over 140 watch models in the past 10 years or so, and that's only counting models which are unique from the POV of the Connect IQ ecosystem. If you count variants like Fenix vs Tactix vs Quatix, there's even more than that.
    I def sympathize with you here.
    To be fair this is what the "Map" section of the manual looks like for FR955, which does support real maps.
    I wouldn't expect anyone new to Garmin sports watches to know this, but a lot of their watches don't support (real) maps. It's considered a premium feature reserved for high end watches.
    I feel like a lot of existing Garmin users expect everyone to automatically know everything that they do, and somehow assume everything Garmin does is intuitive and natural, as opposed to the reality where most Garmin users are just used to what Garmin does.
