Today the watch totaly crashed by starting a run.
Hard reset does not work, i see only the triangel.
was updates.
was updates.
All,
We are aware of the disruption of devices displaying a blue triangle when starting a GPS activity. Holding the power button until the unit powers off may or may not restore functionality temporarily…
All,
Thank you very much for your patience as we worked on this issue. Please see the steps from My Garmin Device Will Not Boot Past the Start Up Screen for a resolution. If you already performed the steps…
Although appreciated, it's completely absurd the only guidance we have are some other users suggesting button combinations to get these devices to power back on but not resolve this issue. Where is…
Yep, bricked Forerunner 255. I started a walk and flashing triangle. A soft reset does nothing.
I'm not using beta firmware; had an update about a week ago.
Additionally the Connect app on my phone…
Just got similar problem when my Forerunner 255 suddenly starten to have a blue triangle blinkning. It happened eventhough no activity had been starten. The only thing wirking is to closing down the watch by pressning Light Button for 15s. Starting it up again only results in the blinkning blue triangle.
Hi Kamphuis/Alex,
I could not switch off my clock. So I tried your thing - that reset the clock, however, now it does not connect to my phone anymore...
Min har också kraschat idag. Testar nu att ladda efter flera försök att starta om utan resultat.
Även min forunner 255 kraschade idag. Prövat starta om ett flertal gånger utan framgång. Prövar nu att ladda upp den…
Hi everybody
I'm french, excuse my poor english. Same problem : a blue triangle. Impossible to swith off the device pushing the start button, even a long time. So impossible to restart the device. Frustrating...
Did you remove device from the GC app and from the BT settings on your phone. Do that then re-pair the device.
Same issue when I start an activity with the GPS on my forunner 255 music. After a hard reset, an update with Garmin Express, the issue occurs again when I start an activity...
I encountered the same problem. The first activity in the morning went without problems, after the second I got an endless reboot loop. A reset with three buttons helped me. But I noticed that in the "bicycle" activity I can't change the background color to black, neither through the watch nor through the app. I hope for an update to fix the problem soon.
I had same with my 965
Doing the button thing worked but it means redoing settings on watch ...which we all love!
