Today the watch totaly crashed by starting a run.
Hard reset does not work, i see only the triangel.
was updates.
was updates.
All,
We are aware of the disruption of devices displaying a blue triangle when starting a GPS activity. Holding the power button until the unit powers off may or may not restore functionality temporarily…
All,
Thank you very much for your patience as we worked on this issue. Please see the steps from My Garmin Device Will Not Boot Past the Start Up Screen for a resolution. If you already performed the steps…
Although appreciated, it's completely absurd the only guidance we have are some other users suggesting button combinations to get these devices to power back on but not resolve this issue. Where is…
Yep, bricked Forerunner 255. I started a walk and flashing triangle. A soft reset does nothing.
I'm not using beta firmware; had an update about a week ago.
Additionally the Connect app on my phone…
Yes, just started it for a run, blue triangle of doom
Found this on another thread. It works but as it says it deletes everything!! Well done Garmin....
1. Ensure the watch is powered off. 2. You may need to hold LIGHT for up to 30 seconds to turn the watch off. 3. Press and hold DOWN, START/STOP, and BACK/LAP. 4. Press LIGHT to power the watch on while holding these three buttons. 5. After the first beep release START/STOP. 6. After the second beep release the remaining buttons.
...this solved my crash loop problem :) but deletes everything :(
I have same issue with my forerunner 255, I haven't even startet an activity, it just happened to show triangle and black screen in a loop
Problem happening on forerunner 265 as well
All,
Thank you very much for your patience as we worked on this issue. Please see the steps from My Garmin Device Will Not Boot Past the Start Up Screen for a resolution. If you already performed the steps involving the button presses and are still stuck on the triangle, please try them again.
If you are still experiencing any issues regarding this, please contact Product Support directly.
Thank you, and we are again very sorry for any frustration!
Doesn’t work for me - even with the other buttons pressed it goes back into a boot loop as soon as I turn it on.
Thank you, very usefull. At least the watch is alive now!
Same issue, tried to set for run home from work, no joy.
Same here
My Garmin also just crashed without any activity initiativ. A blue triangle blinkning. Have closed the wat
