it seem in recent firmware, on daily suggested workout, it suggest for base run 10bpm higher
i usually get 135bpm for base run, now i get 145bpm
No, press the power button for 15 seconds, the watch will then reset but all watch settings will remain.
Yesterday during the run I did it, the record of the run remained in my memory.
You should have pressed continue.
However, the heart rate indicated by the watch dropped by about 30-40 beats.
I also noticed that when the heart rate readings are wrong, the watch has some problem with recording data in the application,
there is a hole, there is nothing in the recording. It does not add up steps, minutes of high activity, etc....
