I only noticed this recently, I'm assuming it happened after the 21.19 update. Sometime when I run I use courses. Normally on the map window, at the bottom, there would be an arrow showing the direction of the next turn, and a distance to that turn. The arrow now seems to be larger, and there is no longer a distance given. Has anyone else seen this change? Any way to get the distance back so I know how far before I need to turn again? Forerunner 255 Music version. Thanks.
Confirm, it still does not work in version 22.22, and I have also not received the still working turn warning about 20 to 25 metres before the turn at least twice. The mysterious hammer-shaped arrow reappeared at the same point on the route.
