Turn by Turn navigation always late
Hi,
I have a Forerunner 255, i search / get gpx files and import these into courses in garmin, and let garmin create directions.
This works good.
However, Always when running, the cues are go left (and i already turned left) These are always 20m / ish too late.
The only explanation i could have is bad reception, but this is not the case. I find it really annoying, that i cannot use directional cues. I have to always check my watch if i'm still on the right track. With a breadcrump in unknown woods, this is annoying.
It would really help me (and i found a lot of this on the internet, but no solution) and other is the cue can be offset to come earlier or later.
Please take my suggestion in mind, or better, fix the wrong cues. I would think it's a map / gps coordinate calucation issue? I get most directions, but their given when i already took the turn. Sometimes thats soo confusiong when you have larger intersections.
, mostly used this for (trail and urban running.
Please adviced
