Could it be that if one uses the track running routine profile one does not take the v02max?
Thanks
As long as you're meeting these requirements, you should receive VO2 Max from Track Runs:
Running activity must be 10 minutes or longer.
Activity must be recorded outdoors with a GPS signal.
Heart rate data from a built-in optical heart rate sensor or from a chest strap.
Heart rate must be elevated to at least 70% of your maximum heart rate for at least 10 minutes continuously.
Please see What Is VO2 Max Estimate and How Does It Work? and My Recorded Activity Did Not Update the VO2 Max Estimate for more information!
