Hello, I have this problem but my friend still saying that I should set HRM not as a separate device/source but as part of the watch. I cant find this option anywhere....
ovekvam, can you clarify what the issue is ? (if there is one).
I use an HRM Dual for all my workouts (no exception). When I launch my activity on the watch, the watch appears to be switching from the IR sensor, to the HRM Dual. When I stop the activity, the watch seems to be using the IR sensor again.
Is this changing with an upcoming version ?
No. But in the last few firmwares, Garmin leaves the optical sensors on while using the chest strap. It can use the optical sensors as a fallback option if there are issues with the signal from the chest strap. In the latest beta version there is an option to switch this off, so it works like before, with optical sensors being dark when using external sensor.
