Elevation incorrect
Since a few months the elevation of recorded activities on my Forerunner 255 is often way off (and I think that messes up other metrics as well). I often record 100m of climbing and 150 meter descending on a 5k run on totally flat terrain.
I don't think it's hardware related, because my watch reads the correct elevation when I calibrate the altimeter. For example: I calibrate with the Run-widget already opened, using the GPS. It reads 5-7m which is pretty accurate. In the recorded actitvity you see the elevation drop to ridiculous numbers like -70m (yes, the Netherlands are below sea level, but not that much).
Some examples:
https://connect.garmin.com/modern/activity/13045802958
https://connect.garmin.com/modern/activity/12942179303
The issue occurs since a few FW updates ago, I'm on the most currect version now 17.26.
Is this a known issue? Any solutions?
