- Vo2 Max: work for Walk, running, trail running. For walk activity, no matter how easy the exercise is you'll get a value (usually totally wrong), meanwhile for running and trail running, you'll get a value only if you run at least 10 minutes. Two problems with this: if you register a walk, it will ruin your previous running or trail running value. The second problem, I do a lot of outdoor high cardio in the wild, I alternate walk / run but I always run less than 10 minutes, so I don't get any Vo2 Max value out of it, unless I register it as walk (which is not appropriate).
- Training status: do not seem to take into account your exercise if you don't register an activity manually, which is dumb because I do a lot of stuff all day long.
- HRV: The watch is warning me lately that my sleep HRV is unbalanced, while my HRV is going up, I get it it's different than my previous past base status, but it should be seen as a positive sign to have my HRV going up (as far as I understand it).
- Sleep tracking score, imo is not very accurate and does not reflect how I feel (hopefully better with the new update).
