Poor GPS Tracking
Hello everyone,
I know this question has been asked quite a lot but haven't found a solution yet among other replies to similar questions.
As you can see below the tracking is quite crazy, and the wrongest part is actually right after the vibration with "GPS signal found" or something like that.
In this particular run I brought also my phone to check if that would have improved the accuracy, but clearly it didn't.
Latest updates are installed.
Also, I am a new user so I'm wondering whether maybe I'm just overlooking something obvious. The above run was a benchmark run from the running coach.
Thank you for your help!
Top Replies
All Replies
  • Among the many posts about this update, this one seems to have the most different experiences reported... so I'll add mine.
    On my non-music FR255 with 16.17 (GPS 5.00) I don't notice a difference in accuracy. I don't really study the map results, but the total distance for a known course seems to be consistent before and after the update. It seems less than +/- 1% variation using the "All Systems" option.
    But I do also feel like it is harder to get the initial lock. Lately, I trigger it to start looking before I step outside and close the door, then get out in the open and stand like a statue with my arm raised to the south-west and see the red arc not really change until it finally blinks to a green arc and vibrates.
    It may have last been on a 13.x firmware that I feel like it worked better. It would often be showing a partial green arc or even get the full lock and vibrate before I raised my arm to check and start the activity.
  • How long does it take for the screen to say "Ready"? Does syncing with your Connect app before starting an activity speed up the process?
    Out of curiosity, does power cycling the device make a difference either?
  • I haven't timed it, but I want to say I might have to hold still for 30 seconds (which feels ridiculously long standing there like a statue). And this is after it's been in the satellite seeking mode for a minute or two while I was getting ready to go. I also think but cannot prove that it will take longer if I don't hold the watch very still.
    I don't have it connected to my phone normally. The phone connection on the watch is disabled and bluetooth on the phone is also disabled. But the ephemeris is showing as "current".  If it shows "missing", then it takes even longer to get a lock, and I would turn on the phone connection long enough for it to go back to showing "current", but usually at home and not at the start of an activity.
    I haven't seen any difference with power cycling. I get good battery life (around 10-14 days) and enable the phone connection during a charge and then restart the watch once at the very end before taking it off the charger.
    Edit to add: earlier in the year, it would usually find itself while I was going outside, so I would either have a lock already or get it in just a few seconds when I looked at the screen and waited to actually start the activity.
  • Today I had problems again.
    I started my run, 100% gps without any delay
    After 2k of running, gps dropped. 2k before gps was backup.
    If done this route quite often in the past without any problems
    I had occasional problems in the past. But droprate has significant increased since the last version.
    Come on Garmin, this is your core-business
  • All,
    If you have reviewed GPS Drift and Environmental Factor Impact on GPS Accuracy, tested out the troubleshooting steps for better accuracy and are still having GPS issues- you will need to reach out to your local support center:
    Garmin Product Support
    Thank you!
  • I sent you a DM for clarification.
