i had noticed that battery drain fast on my forerunner 255 music series.
I had a full 100% charged yesterday afternoon and now it left with 9%!!!! How does it even possible???
I never had this issue before.... anyone having the same problem??
No problems at all. Shut down the watch en restart it after a minute. Mostly this solves it.
Thanks for the recommendation, i have changed to "on demand", let me monitor for few days.
I am on v16.17, pulse 02 is not turned to "on demand" and my watch doesn't drain in a day like what the OP describes.
My watch power consumption for my specific needs hasn't changed after 16.17, it was before and still is after, about a week. No change after this patch.
I'm not sure about others, but i have noticed the battery depleting fast after the update.. I only wear the watch when i am heading for run.. usually the watch is idle.
Yes I don't think that's normal, depleting almost the entire battery in a day sounds a bit extreme.
Are you using the GPS function ? Because I don't and my battery is fine, so perhaps if you do, then GPS is the problem ?
I don't think this is about settings. Sometimes some watches get into a wrong state after updates, and some software is stuck in a loop. The fix is usually some sort of restart.
My first charge with 16.17 ends before I expected. I didn't change any setting. I've just restarted the watch. Usually battery lasts for 10+ days with my usage, I will report again before 30th.
EDIT: 10 days done, stil have 11%, battery is ok with 16.17
