Other than the obvious of the music version supporting music, what are the technical differences between the 255 and the 255M?
I read somewhere that the music version has WiFi but non-music does not. Are there any other differences? For example in the amount of flash storage or RAM in the watch? The specs on the Garmin website state both have 4Gbyte memory/history but would like to double check that's not an error on the website.
I'm currently using a 645 (music) and looking for potential replacement as the strap lugs have started to crack and I suspect not going to last much longer.
I don't use the music feature at all so non music version is probably fine. I do use course navigation a lot (pre-planning courses on Komoot) and regularly tinker with connect IQ apps so wouldn't want to be restricted by a small amount of memory.
Thanks!
