Some Presale Questions
Hi, I am thinking about getting a 255, and it all looks pretty good.
Since software updates are provided, how many years does Garmin plan to give updates?
What is a reasonable guess as to how long the battery will last? If the battery starts to go, from reading I understand that I probably couldn't replace the battery. If I send it back to Garmin, could I get it replaced at a reasonable cost? I see renewed Garmin watches on Amazon. Those say that the watch is no longer waterproof. Would that be the same if Garmin replaces the battery?
Finally, when use I  use the Garmin Connect, is my data stored on your systems?  Do you resell that data?
Thanks very much for any help you can give me.
