I thought I understood my FR255 after a couple weeks of ownership, but now am more confused. I have been using it with slightly hilly walks in my neighborhood in the San Francisco Bay area. I've been repeating the same routes many times while trying out different watch settings. This is mostly open skies while passing some bushes and trees. I imagine the biggest obstacle between the watch and sky is my body or my walking partner's body.
Weeks ago, one favorite route measured out as 3.37-3.39 miles on multiple "Walk" activities I'd set to use the "auto" (SatIQ?) satellite mode. This distance matched my expectations though I've never tried to measure it with a different instrument.
More recently, I made a copy of the "Walk" activity and set the GPS mode to "off", to test with just pedometer estimates. It always estimated a shorter distance perhaps 75-85% of the expected value. I found this a little frustrating that it seems to ignore the customized walking stride length in my profile, so I resumed playing with GPS settings on this copied activity.
I repeated the walk twice with the UltraTrac mode enabled and the watch recorded 3.25 miles. The track on the Garmin Connect Mobile map is a little jagged, veering off the street or rounding a few corners, but it's hard for me to believe it really cut 4% from my actual path.
Yesterday, I did the walk with the "GPS only" mode and the watch only recorded 2.88 miles as the activity distance. However, when I look at it on the Garmin Connect Mobile map, it looks like it followed the route correctly with just a little more wobble than the original SatIQ tracks. I don't see any gap or truncation at the start or finish. I don't see how it can lose 15% of the distance while showing the same loop around the same streets. It looks like a better track (more faithful curve following) than the UltraTrac but measures as shorter!
For all these walks, it seems to record consistent moving time and average cadence info, with only minor variations that I think correspond to my actual pace being a bit off some days.
Does anyone know how a track could look like it follows the right course but then somehow lose a bunch of distance?
I should also mention that I have "3D distance" enabled for all these activities. I do see some variation in the total ascent/descent figures on different days but nothing dramatic enough to explain a half mile difference. One reference SatIQ walk showed 243 ft gained/230 ft lost. The mysteriously short gps-only walk showed 256 ft gained/236 ft lost.
