In the instruction manual is described how to proceed with running power settings at page 54 as follows:
Running Power Settings
Hold UP, select Activities & Apps, select a running activity, and select the activity settings.
Status: Enables or disables recording Garmin running power data. You can use this setting if you prefer to use
third-party running power data.
Source: Allows you to select which device to use to record running power data. The Smart Mode option
automatically detects and uses the running dynamics accessory, when available. The watch uses wrist-based
running power data when an accessory is not connected.
Account for Wind: Enables or disables using wind data when calculating your running power. Wind data is a
combination of the speed, heading, and barometer data from your watch and the available wind data from
your phone
but if I follow these instruction I don't find any of those settings (Run activity). Where do I see those settings ?
Thanks
Bruno
