I just got my forerunner 255 and the backlight is not working no matter I change the parameters or I try to reset it.
Should I return it ?
Ok I have the 955 not 255 but they run the same firmware. I haven't had an issue with mine at all and it works all day until the sleep hours when I have it disabled.
Have you done a Hard power off…
S.M.R. Thank you! Based on your suggestion I checked the hours I had set for sleep. I mistakenly had it set for 12PM instead of 12AM as time to go to sleep. Changing this was the key to enabling gesture…
Hi. I have the same problem. Did you get a proper answer to the backlight problem?
