Forerunner 255 Power Zone targets in cycling and running workouts
Hi everyone, just got a FR 255 but struggling with power zones.  I tried entering them in for cycling and running but don't seem to be updating at all when you build a workout and select Power Target all the zones are based around a standard 200W instead of the 470W for running and 231W for cycling.  Is there some setting blocking it from updating?  Still waiting for Support to reply from last week.
Also in the Android app when you try and type a value in instead of spinning the selector it lets you type but then doesn't update so have to do it the long way
Hopefully Garmin is working on an update to iron these things out.
( edit )
literally 2 minutes after posting this things got weird :
I set the running and cycling power zones again on the watch
checked out a running workout with blocks of power zone 1,2,3,4 and 5 & all the Watt ranges showed as null
I then went on the Garmin connect website and power ranges now look okay.
I then checked a cycling workout and it's using running Watt ranges on the Android app and correct zone ranges on the website, however when you tap into each dropdown to select zone 1 for example then the correct ranges appear, so could just be a display issue on the Android app.
so I think syncing is being problematic it seems, they may be a similar problem syncing data screens which occasionally blank out, especially with connect IQ fields
