BETA - Forerunner 245 Series 6.04
Download 245
Download 245 M
Notes:
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 5.50 to 6.04:
  • Improve the software update process for external accessories. Installation prompts will now appear after an activity to avoid interrupting activity start.
  • Improvements to heart rate broadcast.
  • Add more smartphone app logos for smart notifications.
  • Block music controls and disconnect headphones in airplane mode.
  • Fix dropout issues on Jaybird Vista headphones.
  • Fix a rare issue that could cause heart rate data to appear flat in Garmin Connect.
  • Fix an issue that could prevent LiveTrack from starting when Auto Start is enabled.
  • Fix an issue with workout alerts when the background color is set to black.
  • Fix an issue sometimes causing distance remaining to not display the hundredths digit.
  • Other minor improvements and bug fixes.
Installation Instructions
  1. Connect your Forerunner 245 Music to your computer using the USB cable.
  2. Download and unzip Forerunner245M_604Beta.zip. Place the GUPDATE.GCD file in the \GARMIN folder of your device's internal storage drive.
  3. Disconnect your device from the computer, approve the update on the watch, and wait for the update to finish.
  4. If you would like to revert to the last public release software, place the GUPDATE-550.GCD file in the \GARMIN folder and rename GUPDATE-550.GCD to GUPDATE.GCD. Disconnect the device to install. NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
  • hello, I'm using the beta version and it's stable, except for the battery with high consumption. now the delay is really strange. Another thing, where's the sleep widget
  • Also waiting very patiently for the sleep widget. It seems to have enough polish for them to release it with the freshly released (today) Enduro. DCR also stated trail running v02max is going to make it's way to the 245 from the Enduro. Just another thing to wait for. The toruture Garmin! Grimacing
  • Hi guys
    I still have an issue on FRM245 software version 5.60
    No Vo2Max data, no performance condition , no training status
    Anyone have a fix for this?
    I tried the RHR fix - will try again on my next run
    Any other suggestions?
