245 Download
245 M Download
Notes:
- For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
- Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 5.00 to 5.09:
- Added support for the Track Run activity, which allows you to record outdoor track data, including lap splits and distance in meters, on a standard shape 400m track.
- Added support for Improved Recovery Time, which takes your stress, sleep, relaxation, and physical activity into consideration.
- Improved optical heart rate performance.
- Added a Save Location option to the Navigation menu.
- Updated the look of the Alarm screen.
- Updated the main workout data screen to indicate High, Low, or In Range for the current target.
- Various other improvements and bug fixes.
Installation Instructions
- Connect your Forerunner 245 Music to your computer using the USB cable.
- Download and unzip Forerunner245M_509Beta.zip. Place the GUPDATE.GCD file in the \GARMIN folder of your device's internal storage drive.
- From the RemoteSW folder, copy the GUP3079.GCD file and the 006B310708.GCD file into the \GARMIN\REMOTESW folder on your device.
- Disconnect your device from the computer, approve the update on the watch, and wait for the update to finish.
- If you would like to revert to the last public release software, place the GUPDATE-500.GCD file in the \GARMIN folder and rename GUPDATE-500.GCD to GUPDATE.GCD. Place the GUP3079-504.GCD file from RemoteSW\Downgrades into the \GARMIN\REMOTESW folder on your device and rename the file to GUP3079.GCD. Place the 006B310708-440.GCD file from RemoteSW\Downgrades into the \GARMIN\REMOTESW folder and rename the file to 006B310708.GCD. Disconnect the device to install. NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
