Forerunner 245 Series SW 5.00 is now live
This update can be downloaded with Garmin Express or automatically with Garmin Connect Mobile pending rollout.
Change Log
  • Added support for displaying courses to viewers of the user's LiveTrack sessions. Various other LiveTrack improvements.
  • Added the Pause Training Status feature. Allows the user to suppress some training status feedback phrases and trends. Access the options from the Training Status widget menu or within Garmin Connect.
  • Added in-place editing of data fields.
  • Added additional options to Live Event Sharing. Trigger added for Every Mile.
  • Numerous improvements to music experience, usability, and WiFi.
  • Improved incoming call handling.
  • Fixed problem with device spinning/freezing on activity save due to unintentional file build-up. Note: device will need to sync to Garmin Connect after software update to resolve this issue.
  • Updated numerous widgets to improve usability and look.
  • Fixed inability of device to record longest swim PR.
  • Moved Recovery HR to option on save/discard screen.
  • Updated post-activity summary pages.
  • Improvements to segments handling.
  • Improvements/fixes for on-device weather. Fix instances of missing data.
  • Improvements to phone connectivity.
  • Fixed HRV stress page layout.
  • Fixed a few issues with Virtual Running and workouts.
  • Various other improvements and bug fixes.
    0 Former Member over 5 years ago
    Since the automatic update to SW 5.0 my battery is toast. It used to last 6 but more often 7 days. Now with the same routine, the battery lasts about 13 hours! I changed and tried multiple watchfaces and the best with a plain face is about 4 days. No other changes. Please, I hope someone is lookng into this. I have had the watch for 14 months through multiple SW updates and this is the only issue I've had. In the interval, how do I roll back to the last SW prior to 5.0?
  • I can recommend to make a reset to factory  to clean everything.
    It work very well for me.
    It take less than 5 min to restore all my params.
    This 5.0 firmware is very good and I can use again my favorite watchface gearmin with a 1% drop/hour. (Very correct with so many info at screen)
    Best regards
    PS: It should be very nice idea to develop a small app to:
    - switch to a very basic watchface during Night (during DND)
    -once the morning, restore a heavy watchface with all info you need during the day.
    -> Some watch face propose by default this kind of feature but not all :-<
    --> We can pass from 4 days to 7 days with a battery with a low consumption watchface during night (around 0.2%/h - comparated to my gearmin -1%/h )
     I installed the SDK to see what is possible....
    0 Former Member over 5 years ago in reply to Thomas
    Thomas, Thanks for the reply. I will try that since you recommend the 5.0 firmware. Certainly easier than a rollback to an earlier version.
  • I had the same battery issue. Unpair and pair the watch with the phone again - I mean total pairing again where the phone asks you for security code to confirm bluetooth connection.
  • Totally agree!  And don’t understand why they would move that.  At least give us the option of where it displays or something...
    I have different issue: average HR after update to 5.0 is 20% higher, all stats are now meaningless. Take a look carefully at your data.
    Tried downgrade to 4.87 beta but it is not possible.
    I did a factory reset of the watch and it helped with the battery for a week I got a full normal charge and it lasted more than 7 days and then yesterday I was at 50% battery and I woke up to a dead watch. Is there a way to go back to the old firmware?
    I’ve only had the watch for a little under 2 months and I’m so upset that this is what I’m dealing with now. I’ve done everything I can think of to the watch to make it use the least amount of battery.
    0 Former Member over 4 years ago in reply to Former Member
    Hi, did you try to use that datafile & instruction?
    https://www8.garmin.com/support/download_details.jsp?id=14935
    I have tried couple times and it did not work for me. Still have ver. 5.0
  • I'm now using this firmware since one week and I have better statistic to share.
    Definitively the Beta 4.87 was better that this 5.00 for battery saving.
    ### With the 5.00 it is not possible to reduce the consumption.
            *You can try, to change to a light watchface (without  seconds and refreshed data), disconnect BT-> You will stays at 1,1%/hour
    --> what give max 4 days with a battery
    ### With 4.87, the night, you can success a 0,35%/hours during 8-10hours  & the days a 1,3%/h -> that means that the overall battery time was 6-7/days/battery
    I tried everything, factory restore, all possible tips. -> I think it is a firmware problem.
    --> 1,1 %/hour with an heavy watchface (during day with lot of notification) is quite good but when the watch is not solicited (during night, with a basic screen, without notification) we can not reduce the drain -> And that's the problem of this firmware.
    For all the rest  5.0 is superior.
    - presentation, new design of screen
    - gps connection (less than 5s)
    I detect this morning, some freeze during my running with this 5.0 (first time) . The 180 ppm "metronome" don't bip with regularity, i removed it during my run.
    But i'm a crazy "battery drop testing" benchmarker, and them i'm not happy with this 5.0
