It seems like the connection interrupts and the 245M gets the data from my wirst until it reconnects again (during a run).
The HR drops from 150 bpm to 125 and then back to 150 for example. Anyone facing these issues as well?
During most of watch alerts (laps, training steps, etc.) my HRM-RUN is being disconnected for a while and drops to 75-76 bpm can be seen. Well known issue with the latest FW 4.40, yet with no response…
Correct, it should be an issue with the FR245. The Garmin Support replaced my HRM but problem was still persistent so they replaced the FR245 as well. Unfortunately with no success. Currently they passed…
Hi,
Garmin pushes update as soon as you use Garmin Express or if you connect thru Wifi.
You can avoid update :
* Removing the GUPDATE.GCD file, in /GARMIN, as soon as the device asks for an update.
or
…Frankly speaking i don't know ... I did a different test yesterday with an old HRM from Garmin (HRM3-SS) using 4.40 ...and i got only 1 fail (ont two hours) ...
I will downgrade (again!) today and see what happend
I ll keep you in touch
Okay. In short: we are stuck :(
The system is ALWAYS updating the firmware with the latest version (4.40 for us). We can delay the update (now or tonight) but that's it.
The latest firmware is downloaded when using Garmin Express or when synchronizing via Wifi.
The XML file (GarminDevice.xml) is updated at startup, during synchronization (perhaps more often), and, thus, all the modifications made are deleted (for example: GUPDATE.GCD).
I also tried to change the attribute of the file ... without success.
I'm afraid there is no option but to wait for new firmware ...
Why not;)
I just did a test with 4.20 and HRM-DUAL ..and still got a "hole" in cardio ... just one ...
I wonder if it is not related to the *new* SensorHub ...
Now, same configuration but i'll move to 4.40
<to be continued>
Analysis made by @BEATmeHH makes sense !
I checked previous graphs, and i can see that the drops appears on each watch vibration (e.g. on HR alert)
But it doesn't occur on LAP notification.
ANT: 5.04 / Hub: 3.20
I just ran test and the solution proposed by @BEATmeHH is good. To don't lose HR signal at each screen change (during split run), Desactivate vibrations !
Do you know if garmin team searche to solve this bug ? is there a site with all the bugs referenced?
I saw they launched a FW4.41 beta but no mention of this problem.
