245 timer fields keep repeating 60 minutes in timer setting
Please can you help me?
I have set my main screen as DISTANCE second field TIMER third field PACE
However, when I start a run - the timer (or even when I toggle to Elapsed time - cycles the run time to 60 minutes and then restarts again on another 60 minutes.
This is HUGELY frustrating when you out for a long run only to now know how long the run has lasted for?
The watch is brilliant - I have obviously caused this but I don't know how I have done it, and I cant seem to change it - Its driving me mad!!
Thank you
  • There should be a smaller number that indicates hours.
  •  Are you not seeing the small hour indicator in the attached picture once you've gone over an hour?
    0 Former Member in reply to Garmin-Blake
    Thank you for taking the time to reply
    I’m afraid NO - there’s is just the timer that elapses at the start of a run from 0:00 and gets to 59:59 before going back to 0:00 and the next hour.
    it isn’t doing what I want which is timing a run entirely
    0 Former Member in reply to Former Member
    Just realised what your saying!
    the watch is elapsed timing correctly! Those small digest to the side are the hours! Sorry!
    I can’t say I have noticed - but I will look more carefully when I’m running over an hour - thank you!!
  • Following on from this does anyone know if there is an easy way to make the hour display the same as the other digits? I guess the other option is to use a customised watch face.
    Thanks.
  • Hi Blake, like Petrus I would like to know if there is a setting to make the hour digit the same size as the other digits. It is difficult to read on the run with just a quick glance. An hh:mm:ss setting would make life a bit easier on long runs and ultras. My old FR230 could do it.
