heart rate
2 weeks the heart rate sensor on the watch does not work. If someone has the same problem? Maybe it is related to the software? collecting does not solve the problem.
3.10
  • We would recommend starting with a hard reset (hold the power button down for 15 seconds) before powering it back on like normal. Then ensure the sensor is still turned on by going into your sensor settings from the main menu.
    0 Former Member in reply to Garmin-Blake
    this method does not work. how to reset from settings menu
    when reset, as well as when switching on and off the pulse from the menu, it works for 1 second and goes out. no vents settings do not help
    Heart rate is the speed of the guts beat measured by the number of contractions of the heart per minute. The heart rate will vary consistent with the body's physical desires, together with the requirement to soak up elements and expel greenhouse gas. It is typically equal or near to the heartbeat measured at any peripheral point. Heart rate, additionally called pulse, is that the range of times a personality's heartbeats per minute. Normal heart rate varies from person to person, but a normal range for adults is 60 to 100 beats per minute, according to these results you can also able to measure your heart rate with the help of some heart rate monitoring devices.
