Cant change music volume
Hello,
I hot a FR 245 Music and since I did not have BT earphones before I got a pair and they work with the watch but the music volume is always at max level even if I try to reduce it using the watch controls. The earphones dont have volume buttons so it is just the FR245 in control and the music is painfully laud..
I tried using the earphones with my phone and they work fine regulating the music level. Also I tried connecting to my Bluetooth home speaker and I cant change its volume level using the watch either.
Any help is appreciated.
Cheers,
Edin
  • Hi, I have a solution for this issue. Firstly, connect your BT earphones to your phone. Then, change the volume using your phone. Then, disconnect the earphone with the phone and reconnect the earphone with the Gramin. I think the BT earphone do not have the changing volume function in itself so you need to adjust it via phone. However, you still fail to adjust volume using Garmin. This solution only fix the problem that the volume at max volume at first.
