Opinion: Please offer both soft strap and traditional strap heart rate monitors
I've had an FR 220 for eleven years. It came with a soft strap HRM. But, I've had bad luck with the durability of the soft strap. This is the actual strap, not the electronics module. After the third failure, I bought a new Garmin heart rate monitor with the traditional, old-style strap. By contrast, it, so far, has lasted seven years.
Even though my current HRM transmitter is still working, I'm looking for another transmitter. This is because none of the cardio equipment at the fitness center I use is compatible with ANT+. Most machines are compatible with Bluetooth; some are compatible with 5 kHz / GymLink. I'm interested in using equipment features that use heart rate monitoring such as fitness tests, or heart rate controlled workouts.
I find the only chest strap transmitters that have two or all three protocols are soft strap. But, given my experience with soft strap durability, I am reluctant to buy another.
I do understand that the soft straps wear out and are replaceable. But, replacing the strap every 9 to 12 months or so is an extra expense. Soft straps are the most comfortable, but I don't have a problem with comfort  of traditional straps.
By the way, I hope to keep my FR 220 another ten years.
  • Have a look at HRM 600 - it has a replaceable strap, so when it dies, you can keep the electronics, and buy just a new strap.
  • I'm also a huge fan of the oldskool traditional HR straps. From years ago I remember there were products that bridged ANT+ and BLE, Viiiiva and Wahoo CABLE are things I found when searching for it. No idea about cost and availability though.
    The HRM600 has a lot of functions, but if you only want HR data there are lots of affordable dual ANT+/BLE modules that fit on any standard cheap soft strap that you can replace when worn out. The very cheap ones (<20 euro) often don't have good filtering and don't provide good HRV (R-R interval) data, depending on the software you use, this may impact analysis of activities.
