HRM 600 POD too hard to remove
The HRM 600 pod is extremely hard to remove it, and even while holding the strap in place the clip on the strap is already lifting after a week. For sure this must be a design fault and you should issue new straps that do not clip so strongly. Especially if the manual suggests to remove strap to clean after just 7 uses.
  • I don't know what was changed. I compared both, but could not really see a difference. Only that removing the pod was easy on the new one.
    I've got the new design under warrenty. I orderded the first one directly from the Dutch Garmin site together with a Forerunner 970. After issues with the IM's Garmin agreed to send my a replacement HRM600 when the newly designed version came abailable. That was this week.
