HRM pro not tracking activities
Hello,
I have been using a HRM pro+ for a few months now paired to my FENIX7 as the watch sensor doesn't work to well on my wrist (it severely underestimate my HR).
For the last few trainings, my watch doesn't use the HRM for heart rate tracking even though is indicated as connected on the watch. The activity recaps on the Garmin connect app do not indicate that my HRM was in use (as it used to before). I tried to manually connect the device in the watch menus yesterday but after a few minutes of running my watch lost track of my position and then seemed to switch back to wrist sensing. Garmin connect still didn't show the use of the HRM.
I tried turning the watch off and on, unpaired the device and paired again but it didn't work. I haven't tried changing the battery on the HRM yet but the app says it is at an "OK" level and it still shows as connected to the app.
The first fail came right after I connected my watch to Garmin express through my PC to update maps but it seems it also updated some firmware but I am not sure it comes from that.
Does anyone has any input that might help pls?
  • I have a FR965 with the same HRM , maybe some of this can assist:
    There was a change in the FW that brought in Source Switching , I am not sure if you have than enabled or not. I have it disabled.
    There was also a FW change with the open / encrypted thingthey had to add due to EU legislation.
    You say you have completely unpaired the HRM and then re-paired, I had to do that after these FW changes.
    Do you have the HRM-PRO connected to the Phone? If so maybe try something like Strava and see if it picks up the HR so you know the HRM is working.
    Set up a screen in your Activity with GCT Balance showing , The HRM-Pro+ allows that and then you can check during an activity of it is recording . (I did this when I was having issues)
    You can interrogate the fit file using a fit file reader and that should show both HRM and OHR if source switching is not off. There are a number of posts on that in the forums.
  • Also is it connected to watch with Ant+ and not BT
