I have just purchased the HRM dual. I wet the sensors and started connecting the band.
He does not automatically find it via the app. I then manually search for HRM, but then it only comes up with the HRM fit, pro, etc. I then select the HRM fit. After a short search he comes back and says that he has found the HRM dual.
I try to pair and os progress, only after 20-30 seconds it indicates that pairing failed. I added sensors via my Vivoactive 4. That's where he finds him. After this I also see it in the Garmin app under devices and it is listed under sensors. When I start an activity, the watch indicates that the HRM is connected. However, I don't see a heartbeat in my display.
I also don't see a heart rate on the watch if I don't start an activity. I have included my heart rate in my standard watch face. When I go back to sensors, it is not always connected by default. I then have to go there and it will connect.
But then again no heartbeat. In the above I have turned off my wrist heart rate. When I turn it on, a heartbeat can be seen. But that will be from the wrist and not from the band? What is the solution...?
Thank you. And, yes: I wet the tire several times...
