HRM-Run incorrect readings mid-run (probably due to interference)
Admittedly my HRM-Run is ancient (11 years) but it has been supremely reliable all those years. But lately I see abnormally high HR after more than 30 minutes or near the end of a run. The image shows HRV (Runalyze).
I replaced the strap with a new once twice, and the battery, without effect. What seems to precede the signal going noisy, is often a pause in the activity (arrow). The strap can't have dried out during a 1 minute pause (in warm and humid weather while sweating profusely). But it also happens while running, suddenly the signal goes bad. I ruled out the strap shifting or getting loose, and a bad battery.
Can these sensors get too sweaty (short-circuiting the terminals?) This is probably the one disadvantage of sensors that clip on a strap, not only the pads get soaked but the whole thing can get totally drenched.
Does anyone recognize this effect? Did you find what caused it?
    After another couple of runs, with different straps and different ANT+ sensors, these anomalies always start to occur at the same location and are usually very brief, like the one below. It is in mostly farm land, I think it may be an electrical fence transformer or campingsite wifi. Relieved that my straps and sensors are all good!
