As I mentioned in the title I'm looking for a glue to stick the electrodes that are starting to peel off. Has anyone solved it?
Thanks!
Thanks!
Hey,
I have used glue on basis of cyanoacrylate aka „superglue“ several times on my strap for HRM Dual and HRM Pro.
If you do that, be careful and don’t use too much. Also watch out not to glue…
Replacement straps aren’t expensive. Perhaps consider replacing the strap.
this depends on the country you are in
There are many offers on Aliexpress compatible with the dual sensor, they cost about $5-$7.
Try searching for - polar wahoo garmin
Hey,
If you do that, be careful and don’t use too much. Also watch out not to glue your fingers to the strap
For me, it worked fine, functionality is still there after glueing the straps.
If ordering from Aliexpress, order a few from different 'shops' instead of 5 of one type. Most are OK but are some that are such bad quality that they break or don't work well, sensor pops off etc., and you can't tell from the pictures or reviews. It is a bummer to be stuck with 5 terrible straps.
Thank you, I already bought it once. Easy to rotation with dual main belt. I looked at the number of sales and reviews, there were no problems.
This was the solution, thank you!
