Hi all
Is anyone knows, why in Garmin connect (PC) my VO2 is 42, and on my watch showing 35? So which one is accurate now, because i don't think that my VO2 is 35
Hi all
Yeah well... thx anyway. One thing came up in my mind, that when i bought the new watch, and sold the older one, i registered the new one, with the same account. So if on the old one was a good VO2 maybe its summing up the results with the old one, and that's why is registering different VO2-s . But than if it syncs why does it like this?
What device do you have and what did you have before?
I've changed and added many devices and not had this issue , apart from when the new format GC was setup recently and I had some small discrepancies between GC and the watch but that seems to be OK now..
Have you tried resetting the watch completely and resetting things up from that clean base , as then one would adssume the VO2 would pull from the Connect system , but it may depend on the device.
But if i look at your posts , the difference is between Connect Web and Connect mobile also? Is that correct?
Have you deleted connect app completely from your phone and reinstalled it from clean also.re-pairing your watch also.?
