I picked up a secondhand HRM Pro last week from CEX, so it has a warranty, but as they test everything before sale I wasn't hoping to need to use it..
However I've had very poor results both running with my Garmin Fenix3, and on Zwift using AppleTV.
The unit can't seem to maintain a connection for very long.
I replaced the battery last night, and I've still had issues today, so wondered what other options I can take before returning it?
I've previously been using my original HRM Run strap which came with the Fenix3 back in 2015. It's never missed a beat, and aside from having to buy new straps and change the battery, I can't fault it - but after my laptop died, and I got an AppleTV to use Zwift instead; I wanted a HR strap that can connect via Bluetooth, since the old HR unit was just Ant+.
I suffered about 5-6 drop outs within an hour on it's first use with Zwift last week - which was a real pain as the Wahoo Headwind kept cutting out too.
And then I went for a run at the weekend which was fine.
But then I've gone on 2 runs this week, and it's not been able to hold a connection. The run today was with a new battery too, in case that was an issue.
It seems to connect to the Fenix, and then instantly lose connection again, and again - repeatedly.
For my last 2 runs, it's connected for a second, showing 72bmm, and then disconnected. It might then reconnect and show my actual HR, but then disconnect again, and reconnect back at 71bpm.
I don't know how it's connecting to the Fenix via Ant+ or Bluetooth, is there a way to find out? But the issue with AppleTV and the fact that it struggles to stay connected to Garmin Connect on my phone, makes me think it's a Bluetooth issue.
As I understand, the HRM Pro is meant to be able to store data too, but attempting to download offline data afterwards does nothing either.
I always wet/lick the connection pads before putting on, and that works fine on my old strap; but even fully submerging this before a run doesn't seem to make a difference.
I tightened the strap too, but that didn't help. Been a wearing HR strap for activities for past 8 years, so it's not a new concept to me.
I've tried unparing, removing from device and re-pairing again...
Garmin Connect says it's on Firmware 8.8 and says that's most up-to-date version.
Anyone have any other suggestions please, before I return it?
Thanks!
First use, on Zwift:
First run, which was fine:
Second run, disaster:
Today's run, bigger disaster, with new battery:
