Since 2 days Connect IQ data field STRYD ZONES doesn't appear anymore on Fenix 7
I used this data field for a while to show power output of the stryd pod on the run activity , but since 2 days I just can see a white screen on the watch
without any data. I re-installed the data field via connectIQ and re-connected the stryd foot pod, but no change ?
Anybody ales with this issue?   Maybe caused by a SW update?
  • Same issue here. New Fenix 7 this week, have used Stryd no issues on Fenix 6 previously. I have been able to get it to display the two runs I've had with it by looking in run settings, finding it under accessories and seeing that it shows connected, and returning to the run mode. It seems to show up then. Hopefully that helps others, and hopefully they fix it soon! I'm glad it's a new issue, it gives me more hope that I won't have to use this work around forever!
  • I have this issue too. It appeared with software update 14.36. The only workaround seems to be the one as suggested by Triasand.
  • Hopefully that helps others, and hopefully they fix it soon!
    Hopefully you'll contact Garmin Support too...
  • I contacted Garmin and they thought it sounded like a Stryd issue. I contacted Stryd, and they weren't sure. I also had issues getting into the Stryd Workout App, so they seemed to focus more on that. I have 14.36 Garmin, and made sure the IQ apps were both current. Strangely, on 10/1 the IQ power field started to work and when I checked the Workout App a couple of days later, that was also working....nothing has updated, no other changes. I also had no resolution with either Garmin or Stryd, it just started to work. I had uninstalled and reinstalled both IQ apps, but I still had errors and had to do the work around for the power IQ field, so I'm not really sure what changed to make it work.
