HRM-Pro Irregular/Delayed & Spiking HR
Two days ago, I went for a 5K run with my HRM-Pro synced to my Phoenix 6. I always wet at least the strap's pads with water or saliva, check to ensure it is connected to the watch, and then when I know everything's connected, I go for a run. I was doing zone 2 HR training (141 to 156 BPM for me) and things seemed to work fine. The watch appeared to track and alert low and high heart rates appropriately. The terrain was generally flat with only minor grades to incline and decline, so my heart rate seemed to rise and fall more or less normally while running and walking.
Today, I did a 10K in what I thought was going to be zone 2. The terrain was similar, though there were more slight uphill grades. What confused and annoyed me today was that my watch, synced to my HRM-Pro, kept reporting that I was in HR zone 1 (less than 141 BPM) for almost the majority of the first three miles, occasionally bleeding in to zone 2. based on how I performed two days ago, there is no way this was accurate, but I kept on running and when ascending a steep hill, my HR rose to 166 immediately (zone 3 aerobic), so I stopped to walk, and then the watched spiked right up to 185 BPM! I was so confused, and so I continued walking until my HR dropped back down in to zone 2 at about 145 BPM. From then on, the watch stayed in zone 2 / 3, as if reading normally, like the HRM-Pro had finally realized I was doing something, and looked as if it was reporting HR accurately when compared to the 5K I ran two days ago.
Is this normal? What could have caused this? After every run, I rinse my HRM-Pro with cool water thoroughly, and I try to soak the pads thoroughly in water before running, but sometimes I have no water and so I simply use saliva. This has always worked in the past. Is my HRM-Pro faulty or damaged? Maybe some sort of syncing issue with the watch?
Curious as to what you guys think. Please let me know if there's anything I can do. Thanks in advance!
  • i bet your respiration data was also missing during those spike up and the below actual bpm time
  • After 10 months of perfect results mine has started behaving in a similar manner to yours. I immediately changed the battery but the symptoms persisted. I checked the voltage of the new battery and it was indicating 2.8V so I changed the battery again for one that I had just bought with a voltage of 3.3V. Situation remains the same; I have tried connecting with both Zwift amd my Edge 830 head unit with no difference in results so by a process of elimination the problem is with the HRM unit for me.
  • You don't say how long you have been using the HRM-Pro. Was it particularly dry?
    There are a few reports in this forum with similar issues.
    Some fixes(assuming it is not faulty):-
    Replace the battery (including putting it in backwards for a short time to reset the HRM)
    Use electrode gel. This can be helpful in dry conditions or for those that have hairy chests.
    Use a natural not synthetic shirt/top.
    If it happens in the same location, it could be radio interference.
    Has it paired correctly using ANT+. It should show up as HRM-Pro:(six digit number).
    I have been using one for several years. I have been lucky as the only issue I have had has been walking home with it wet in my backpack and it sending erroneous data to my watch. I had to put it in a Faraday bag to stop this for happening.
  • In my case, I live in the UAE and currently at 5-6 ish in the morning it is 32+C and 80+% humidity and I am drowning in sweat which is no real change from every other day of the last 10 months.
  • I've been using my HRM for about a year in a subtropical environment. Thr battery was replaced recently. I tried a small amount of electrode gel yesterday and went for a 5K run. Thr HRM still reads low at about 145 BPM when my watch reads 166 while I run harder than usual. I'm still convinced the watch is inaccurate. I tried running in a different area this time and the issue unfortunately persisted. I put the HRM directly to my chest for the first half mile and then through a dry fit shirt the second half mile but no change occurred. There was some corrosion in the battery area that I cleaned out with a dry rag before applying a small amount electrode gel and replacing the battery so I'm wondering if I just got unlucky and it got damaged due to water or sweat with an improperly sealed O Ring. I am looking at ordering the HRM Pro Plus if it keeps up. Appreciate the responses so far.
  • de acuerdo, me sucede lo mismo, ya he competido en varias carreras en donde estoy dando el 90% de mi capacidad y la banda HRM-Pro registra que voy a 100 o 120 BPM... algo que no es para nada exacto en la medición, al desconectar mi banda y solo dejar que mi reloj lea mi BPM las pulsaciones suben a 160 BPM. creo que es un daño en la banda, en la tienda Garmin me dicen que cambie la batería ya lo hice pero no ha habido cambios, sigue leyendo mal las pulsaciones
  • The watch HRM is not as accurate as a chest HRM. It is affected by movement, skin colour and skin hair.
    If you had corrosion on the battery terminals then there could be more on the electronics. You could try an electrical contact cleaner, however, corrosion has probably already done the damage,
    Good luck.
  • Hi, I had similar problems. It only helped when I put the chest belt in the washing machine and washed it.
    Washing under water was ineffective.
  • HRM Pro Plus and Fenix 6 X Pro.
    My last runs are like that. I went to two cardiologists because I thought that something is wrong with my heart but I am healthy of course. I have the strap 6 months like you. I had also hrm pro which I sent it back because the electrodes were complete damaged with high heart rate readings after few months. I really can't understand what is going on. Every run is faulty now. It disconects for some seconds and then I have high heart rates 230bpm. Also sometimes before it goes up it goes low bpm.
    Do you have any updates from your issue?
