I'm a long term Garmin user. I've had four Edge GPSs, and (I think) six HRMs - I managed to lose two (really reliable!) ones in the past two years.
Almost exactly a year ago, I bought a new HRM Dual. I used this with both an Android tablet, running Zwift, and with an old Edge 1000. I also used one of the really old Garmin HRMs for some rides, and because the 1000 didn't record the sensor used I no longer know which I was using for which rides (except for Zwift - the old HRM didn't have Bluetooth of course).
Anyway, although I didn't spot it straight away I think there was a problem straight away. I was getting short dropouts - just for maybe three or four seconds. These did not happen when the HRM was connected to the tablet - at least, I can't find any examples. I have very few rides recorded on the indoor trainer, but using a Garmin head unit, but I also can't see any dropouts on the (only) one I've looked at. In May, I replaced the 1000 with a 1040, and the problem continued completely unchanged.
A few days ago, as the HRM was nearing the end of its waranty period, I contacted Garmin Support who were, I have to say, just superb. They replaced the HRM without quibble, and very quickly. However, I still have exactly the same problem!
I wonder if it could be caused by a conflict with another sensor, but as far as I can tell there's no correlation between its use with various other sensors - a Varia tail light, and three different power meters (2 x Power2Max and a pair of Assiomas). Behaviour is the same whichever power meter is being used, and regardless of whether the Varia is in use.
The problem occurs rarely, if ever, during high intensity efforts. This is a 22km time trial a few days ago, and is fine -
https://connect.garmin.com/modern/activity/11733022041
Whereas this - with dropouts, if not the worst - is a recovery ride a couple of hours later -
https://connect.garmin.com/modern/activity/11734314720
I could probably live with that, but the problem has frequently become worse, with major drops for extended periods, like this (with a new battery, by the way) -
https://connect.garmin.com/modern/activity/11623697997
Although the (a...) HR has recorded for much of the above ride, the final forty minutes is far lower than reality, and actually if you check respiration you'll see that it had basically failed for the last hour of the ride.
So - I have tried:
- A variety of clothing - so not static, I'm pretty sure
- Batteries. Lots of them - different makes, different power ratings, original ones, replacement ones...no difference.
- Position - high, low, left, right. Sometimes moving it makes a difference, but it doesn't sort the problem out.
- Pairing and unpairing. Lots of times, including mid-ride. No difference.
- And obviously two head units. No difference.
Does anyone have any ideas?!
