HRM-PRO Plus
Hello.
I have been an owner of a Phenix 5S Pluss for years, but latelly I think the heartrate monitor of this unit is off. Strange readings when eunning. I therefore decided to pick up a HRM-Pro Plus band. I have now connected this to both my watch and Garmin Connect app on my phone.
My question is, when runnign now using the running "app" on my watch where I monitor my heart rate when running, wil it be data fromn the HRM-Pro Plus band or still from the watch sensor?
Thank you.
Top Replies
All Replies
  • wil it be data fromn the HRM-Pro Plus band or still from the watch sensor?
    When you have paired the sensor to the watch, and wear it at the start of an (running) activity, the watch will always use the external sensor.
    You will get a short notification at the start, that the sensor connected, but will not see the status during run.
    Still, you can check it: Have a look under the watch - during run, the green lights of the sensor are switched off and stay off. You could even take the watch off and still will see your pulse on the display.
