I compared the Vertical Oscillation, Ground Contact Time, Ground Contact Time Balance and Cadence data from the RDPod and the HRMproPlus Band. RDPOD data in red and band data in light blue. The balance is perfect with the RDpod averaging 50/50 while with the band it is 52.1/47.9. Ground contact time is 202ms with the headband and a bit higher with the RDpod. Note that from the meta the values are almost identical. Cadence is identical and vertical oscillation is also different with the lowest range and with the highest RDpod, values that both align as with the midstroke ground contact time. It should be noted that from the middle of the race, while the oscillation and ground contact time values align, the balance (around the 6th km) is misaligned, and by a lot. How do you explain such a difference between the ground contact time balance? Could it be that a change in the location of the Chest vs. Butt sensing makes such a difference?
