i can't see tempe sensor on garmin connect
Hi all,
I can't see my tempe sensor on garmin connect in the below page
it's important to know the battery status.
thanks
  • The Tempe is an always active low power device that transmits data about every two minutes. They rarely, if ever, transmit their battery status.
    Garmin Connect relies on the compatible Garmin device they are paired to to report the battery status. On all the devices I have my Tempes connected to I have never seen a battery status reported for any of them in the three years I have had them.
    For this reason I expect it is by design that they are not listed
  • I have never seen a battery status reported
    Just by coincidence, I was on a walk today and an alert popped up on my fenix stating my Tempe Battery is Low.
  • I'd be interested to know the voltage of the battery when you replace it. I recently replaced the battery in one of my Tempe and it was down to 2.6 volts but still working. (Most other sensors quit working at around 2.9 volts.) This was the original battery and has been working for at least two years.
    I replaced the battery shortly after my walk.  Used battery voltage = 2.88V.
