An upset story.
After two years using the HRM-Run, bought mid 2019, and a single battery change, my HRM began a weird behavior. It started with miss reading the HR and then after a month died.
As I wouldn't loss activity precision, decided to buy a clip in model and got a HRM-Dual in October 2021 wondering it wasn't going to have same fate. Couldn't made same wrong choice twice!
Last June I had to change the Dual battery. It has last for about three weeks and same behavior developed. First HR misreading and it died.
Now I really don't know what to do. I'm currently using my Fenix 6X to relay HR to the Edge while cycling, unfortunately the precision for this kind activity is almost useless.
Is it time to look other brands?
Here is some images showing cracks in the case body, mostly on the RUN. On the Dual there is a single crack in the screw housing however the circuit board is filled with salt and probably the other side is for sure corroded. The Dual cap is clean, concluding that moisture and sweat hadn't went trough the seal.
