HRM-tri battery drainage
Hi, all!
Looking for any tips to avoid this annoying battery drainage that I am facing with my HRM-tri HR belt paired with Fenix5. Currently, I have varied through multiple batteries and they all end up dead after few days.
Tried to look into available information but up to this point it all addressed moisture damage. In my case that may not be the case as I don't see any signs of cracks, deformation etc. and moisture remains in the HRM shell.
In one case the battery even died without me actually going out for a workout.. just as I replaced and tested it, while it sat there on counter for few days, which leads me to think it may be something software related.
Has anyone faced same issue and came up with solution?
Even the strap is kinda old I would still like to get most of it, and avoid replacing if it seems to work fine (save for drainage).
Best,
TR
  • I had the same problems with my HRM Run. No visible cracks where moisture might have gotten inside but the battery was dead after one day. The strap was 1.5 years old. Garmin replaced it by a new one. That strap wasn't a year old when the same problem appeared. Garmin replaced it by a new HRM Pro.
